disc brakes - super h
Posted by nspec on April 29, 2007 at 14:00:47 from (72.87.118.211):
I"m replacing the disc brakes on my 53 super h. I got everything apart and the discs were all glazed, while the housings/drums/actuators had light surface rust, dirt and some water inside them. Is this normal on an older very used tractor?
How do I prevent the water from getting in? No oil leaks, so do I really need to replace the oil seal? Also, if no oil leaks, can I assume no water getting past the seal to the gear oil?
Thanks in advance!
