Re: 1206 hydraulic system questions ???
Posted by K.B.-826 on May 01, 2007 at 21:29:10 from (24.180.143.209):
In Reply to: 1206 hydraulic system questions ??? posted by Way Up Here on May 01, 2007 at 06:03:45:
Like the Vet said, there are 5 plugs, but keep in mind that the final drives are totally seperate from the transmission case, unless it has been updated. The update was done by removing each final drive and drilling a 1/2" hole through the trans case, which would allow oil from the transmission case out to the final drive. See the pipe plug about halfway up the backside of each final drive? That's the check/fill plug. After you have drained and refilled the trans, remove these plugs and see if the final drives have oil in them, if so, it's been updated, if not, you'll have to fill them up through the check plug. Keep in mind that they may not be full right up to the check plug, as the oil level in the trans case is only about as high as the 1000 RPM PTO shaft.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
