Re: 400 missing
Posted by RustyFarmall on May 02, 2007 at 04:48:25 from (66.43.253.62):
In Reply to: 400 missing posted by LeeCramsey on May 01, 2007 at 17:54:43:
A worn out or close to worn out distributor will cause those symptoms. The bushings and the shaft will develop "play", and then the spark is delivered at varying intervals instead of the exact interval. The advance weights and springs also need to be in good condition. Also, weak valve springs will cause problems such as you describe while the engine is idling or at a low load or no load condition, and seem to work fine while under a load.
