Re: 6 volt cutoff verses regulator cub
Posted by jaw3254 on May 02, 2007 at 13:37:31 from (66.212.145.121):
In Reply to: Re: 6 volt cutoff verses regulator cub posted by John T on May 01, 2007 at 17:44:10:
thanks john for the info i have 4 terminal regulator if i dont use the 4th terminal what do you do with the wire you took off the field terminal on the generator just tape it up and dont use it?
