Re: Super A has no voltage at coil?
Posted by JPM in WA on May 05, 2007 at 00:17:22 from (64.40.45.148):
In Reply to: Super A has no voltage at coil? posted by JPM in WA on May 03, 2007 at 14:10:33:
Thanks everyone for the advice. My SA is running better than it ever has. Thanks again.
I basically re-wired the whole electrical system and changed out the ignition switch.
