Re: Pros and Cons to using oil as coolant
Posted by Bus Driver on May 11, 2007 at 16:35:37 from (66.226.60.252):
In Reply to: Pros and Cons to using oil as coolant posted by JohnG(TX) on May 11, 2007 at 08:44:16:
In the days before permanent anti-freeze, some drivers would use kerosene as a coolant in cold weather. It probably worked reasonably well because of the cold air temperature. But a leak- very common in those days- could result in a cremated car.
