Pros and Cons to using oil as coolant
Posted by JohnG(TX) on May 11, 2007 at 08:44:16 from (216.136.20.34):
I have heard that some farmers were using oil in the cooling system instead of water. I can see several advantages to this, along with some drawbacks. Here is what I can think of:
Pros:
No rust in the water jacket and radiator.
No freezing and busting of the block.
If you have a cracked block, you don't trash your oil and engine by having water in the oil.
Water pumps stay lubricated.
Cons:
Possibly slower heat transfer to oil than water.
Water boils to remove heat, oil does not, so maybe overheating.
Radiator hoses degrade in contact with hot oil.
Thermosyphon may be slow with thick oil in winter.
Radiator leaks will leave oily spots that don't evaporate.
I'm sure others have views on this. Suggestions? Ideas?
