Re: Pros and Cons to using oil as coolant
Posted by Haas on May 11, 2007 at 18:53:43 from (12.65.54.248):
In Reply to: Pros and Cons to using oil as coolant posted by JohnG(TX) on May 11, 2007 at 08:44:16:
You would have to cirulate at least twice as much fluid using oil as with water to do the same amount of cooling. I don't think this would work at all except possibly in cold weather when you don't need as much cooling capacity anyway. Of course if the system is designed for it, it can work, as some of the old-old tractors used oil coolant.
