Re: Pros and Cons to using oil as coolant
Posted by NawlensGator on May 12, 2007 at 08:04:10 from (74.230.217.151):
In Reply to: Pros and Cons to using oil as coolant posted by JohnG(TX) on May 11, 2007 at 08:44:16:
The specific heat of oil is about one third that of water. The same amount of heat will therefore raise the temperature of oil 3 times that of water. The rate of heat transfer from the engine to the coolant is proportional to temperature difference between the engine and the coolant. At the same coolant circulation rate, the oil will be hotter than water and therefore the heat tansfer rate to the oil will be lower. The engine will therefore run ALOT hotter with oil coolant to transfer the same heat generated by the combustion. One BTU of heat will raise the temperature of one pound of water one degree F while oil will heat up 3 degrees F. If the water heats from 90 to 200 deg F, the oil will heat to 420 deg F. Based on some approximations, yout engine metal parts will run at least 80 to 100 deg F hotter (probably worse). Also: 1) The maximum temperature of water entering the engine is limited by the radiater pressure. If it is veneted, the maximum temperature is limited to 212 deg F. Oil on the other hand can get to 400 deg F or more. 2) Oil is lighter than water so your water pump, while circulating the same volume (actually less with oil due to higher viscosity), will ciculate about 20% less pounds per minute than with water. Looks to me like you may reduce cooling side corrosion at the expense of burnning your engine up. Try it and let us know how long it takes to burn up the engine.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
