Re: Timing on M
Posted by turbos10 on May 12, 2007 at 20:46:03 from (71.48.172.104):
In Reply to: Re: Timing on M posted by ChadS on May 12, 2007 at 20:15:21:
Thanks for the input guys. I am actually not sure which notch is TDC on #1. There are two marks about 1/2 inch apart when #1 is at TDC. Without pulling the cover I can not verify, but I expect there is one for initial timing and one for full advance. I guess I need to know if anyone has seen this and what the value is for each mark. I actually already have a box, electronic conversion and MSD coil. In a turbo engine setting to maximum advance works pretty well for something like a puller. It has to be retarded as boost goes up so if you set for max boost it works out well. By doing this timing is fast at idle for response and a little slow in mid RPM to increase EGT and boost quickly. My engine is not really your run of the mill engine; it will be turning close to 5KRPM at 20+psi if all goes as planned. It is a 4.25 bore, girdle, studs, arias pistons, two disc slipper with steel flywheel. I plan to come out of the hole at around 3500RPM, and it pulls in 4th gear. I hope to add more gear later to get the tire speed up. Sounds pretty good with the big Holset and 4 inch pipe :). Cant wait to hook her to a sled!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
