SC Hydraulics Problem - Long
Posted by Skycarp on May 17, 2007 at 18:08:05 from (206.81.147.17):
I hope someone here can help me with my hydraulics problem so I won’t have to go at it blind. I am restoring an SC, with fast hitch. I am new to Farmalls and their hydraulic systems. I have the IH-8 manual and the Blue Ribbon service manual for the touch control. I have read the Troubleshooting Test Procedure but do not have a test valve to check pressures so I do not know if I can follow these test procedures. The hydraulics worked fine before the teardown for restoration so I left that system mostly as it was. I did replace the manifold tubes from the pump to the remote valve/cylinder block. I used new O rings at that location. I drained and cleaned out the cylinder block and installed a replacement filter unit. I did exterior cosmetics like replace the cylinder boots and actuator valve boots. I did not open the cylinder block. I did not go into the hydraulic pump. The pump stayed on the engine as it was. Now the problem, upon engine startup today for the first time, with new hi/tran fluid in the hydraulic system, the system seemed to work as designed for about two minutes. The fast hitch cylinder operated, the implement arms rotated forward and rearward. Then everything hydraulics came to a stop. Nothing works when levers are moved. One rock shaft is forward and one is rearward. The fast hitch cylinder is in the down position and does not move when the remote valve is worked. I topped off the hitran level and worked the control levers for 20 - 30 times. Nothing! To search out the problem I drained the fluid, took out the filter and it was clean and not plugged. I took off the manifold tubes between the pump and the cylinder block and turned over the engine to see what I could see. Nothing jumped out at me as a problem. Do I need to remove the pump and rebuild it? Do I need to take the cylinder block apart and rebuild it? Any suggestions to get the hydraulics working would be appreciated. Thanks in advance.
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
