Re: Spark found
Posted by Janicholson on May 17, 2007 at 19:49:24 from (66.173.50.154):
In Reply to: Spark found posted by CNKS on May 17, 2007 at 19:05:05:
Lift one rear wheel and put it in high gear. Pull the plugs and it will be very easy to turn it with the rear wheel. The compression will taper off as the piston nears TDC due to far less piston movement. you can even put a piece of vinyl plastic in the spark plug hole to assure you are nearing TDC. (remember that TDC can be on the exhaust stroke as well as ccompression, it is still necessary to check for the compression with a thumb, or a whistle placed in a rubber gromet to fit the plug hole. Good luck, JimN
