Re: Not to late to celebrate!!
Posted by John S-B on May 17, 2007 at 20:17:39 from (64.12.117.8):
In Reply to: Not to late to celebrate!! posted by Al L. in Wisc. on May 17, 2007 at 15:24:29:
All you Norwegians, Danes and Swedes came all the way over here and immediately went to the frozen flat tundra known as the upper midwest. I guess you guys don't mind bitter cold, but you just can't stand walking up a hill. ;^)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
