Re: CNKS Intake solution
Posted by CNKS on May 20, 2007 at 19:21:43 from (204.249.178.32):
In Reply to: Re: CNKS Intake solution posted by MN Scott on May 20, 2007 at 07:58:29:
I fixed it. I loosened the bolts that hold the two halves together, and tightened the bolts to the head first. I thought I did that when I first installed it, I just didn't get it lined up right. I am repeatedly able to make simple things complicated. On my manifold, intake and exhaust are tightened by the same bolts using a thick washer between them. I doubt if I have more than 30 lbs or so torque, my gasket can be squashed -- not IH, came with the engine kit.
