Farmall Tractors Discussion Board |
Re: Coolant getting in the base on super c ?
Posted by RKS on May 09, 1999 at 13:00:00:
In Reply to: Coolant getting in the base on super c ? posted by MT on May 09, 1999 at 12:37:47:
you already have a 90% chance of knowing the problem. He either didn't replace the gasket, or didn't put the new one on right. Hope it isn't the other 10%, which means cracked block, or head. Only, don't run the tractor until you get it solved. The oil will be ruined and not lubricate properly, and you'll burn up the bearings. The owner may have seen the coolant and said "adios." Good luck. RKS
Post a Followup
