Re: brake/clutch shaft and pedal bushings
Posted by GordoSD on May 29, 2007 at 18:49:33 from (66.115.200.140):
In Reply to: brake/clutch shaft and pedal bushings posted by nspec on May 29, 2007 at 18:26:50:
I just did mine. Friend welded Brass/bronze on the shaft and I filed and sanded it down. 4 inch 40 grit flap wheel on the angle grinder, then b=====d file, then emery paper.Bw sure and pick up the correct thrust washers for assembly. They also work well to use for filing gauges.
Gordo
