Re: Super A hydraulic pump woes
Posted by mark on May 29, 2007 at 20:41:33 from (172.164.53.154):
In Reply to: Super A hydraulic pump woes posted by Karl Hamson on May 29, 2007 at 20:19:48:
this may sound stupid....but are you sure the pump is turning when the engine is running? If the thing sucks and blows oil when turned by hand...sounds to me like it's fine. Loosen the return line at the reservoir while it's running and see if it blows oil out. If so, the pump is working and the problem is in the reservoir/control valves.
