Re: 140 steering
Posted by Hugh Mackay on June 01, 2007 at 17:45:44 from (209.226.106.33):
In Reply to: 140 steering posted by badger Bob on June 01, 2007 at 15:04:12:
Bob: If the steering wheel shaft has no end movement those bearings will be fine.
Usually most of the problem is two woodruff keys on the vertical shaft in steering box. Inside the gear has one and also the steering control arm has one. Between them, and if bad enough one can get over a full turn of free travel on the steering wheel.
