Re: Gaskets vs RTV or Permatex
Posted by justanothercase on June 01, 2007 at 20:06:38 from (72.20.69.40):
In Reply to: Gaskets vs RTV or Permatex posted by JohnG(TX) on June 01, 2007 at 11:20:51:
you could get some gasket paper and tap out a new one.i use rtv/permatex with most of my gaskets it holds them in place and protects the hearing of anyone around ;-)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
