H Rear End bearing problems.
Posted by Bob Kerr on June 03, 2007 at 13:34:50 from (205.188.116.138):
When I changed the rear end grease peices of a bearing cage came out. It was the wavy type for ball bearings and about 3/16th" wide. Anybody know what bearing it might be from before I tear into it? I am in the process of changing rear axel bearings right now and before I took it apart I thought it may have been one of those but those cages are real big compared to the peice that came out. Any ideas?
