Re: Problem with F130 Tranny
Posted by Hugh MacKay on June 03, 2007 at 16:27:10 from (209.226.106.46):
In Reply to: Problem with F130 Tranny posted by EZ on June 03, 2007 at 13:24:26:
Ed: Jack the rear wheels, try turning them by hand and listen for the noise without engine running. You could have a broken brake drum. Look at the activators, these are not the same as Cub, A or SA. There is a fulcrum pivot at end of brake pull rod, and both ends of brake band hook to that. A broken drum can jamb up on that pivot device.
My next move would be remove the pans on bottom of final drives. The large bull gear does not have a lot of clearence, thus broken pieces can jamb that as well. Those pans look rather flimsey, however I have seen them withstand a broken part being pushed by the bull gear.
