Re: 130 Fuel line
Posted by Bob on June 06, 2007 at 08:13:30 from (69.178.229.154):
In Reply to: 130 Fuel line posted by chad504 on June 06, 2007 at 06:40:49:
Does the compression fitting screw INTO the sediment bowl, as it does on MANY of these old tractors? (IF the setup is still "as original"?
If so, you need 5/16" steel line and the part number for the fitting is in the post linked below:
