Re: Stuck M Update
Posted by Bob Kerr on June 07, 2007 at 07:56:52 from (64.12.117.8):
In Reply to: Stuck M Update posted by StevenL on June 07, 2007 at 06:14:34:
I have had some old guys tell me to get one unstuck, to do all the soaking stuff, BUT jack up one wheel and put a concrete block or something like that under the wheel so the tractor will fall off the block when it losens up. have tractor in gear and it uses the weight of the tractor to put a little force on it. They said to just leave it there like that and when you see the wheel on the ground the engine will have moved. One guy also said to hook up a 15ft or longer pole to a jacked up wheel and put some weight on the end of the pole, when the pole is on the ground it will be loose. Might be worth a try. and should keep the neigbors from chuckling. Good luck with it.
