Re: oil out the axle seals?
Posted by GordoSD on June 07, 2007 at 09:30:07 from (66.115.200.140):
In Reply to: Re: oil out the axle seals? posted by jonnnny2006 on June 06, 2007 at 23:39:10:
Sounds like your carb needs a better rebuild. You have to get rid of that black exhaust, way too rich. You need to lean down to bring up engine temps, keep plugs and combustion chambers clean, develope HP. You can't do any of those things running rich. Get you F/A mixture right and most of your other problems will likely disappear.
Gordo
