Re: Clutch Hassle
Posted by Allan In NE on June 07, 2007 at 17:20:37 from (148.78.243.25):
In Reply to: Re: Clutch Hassle posted by the tractor vet on June 07, 2007 at 17:12:45:
Yeah,
Took the picture before I started on that rascal.
Had the wife in the cab watching the light; never went out as I turned the bolt from below.
So, then I tried it by myself and held the clutch down with a piece of 2X4. Turned a couple of turns and then would check, turned a couple of more turns and then would recheck. Never, ever saw that light go out all the way down the adjustment bolt.
Yeah, I was on the correct bolt.
Allan
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
