Re: Clutch Hassle
Posted by The tractor vet on June 07, 2007 at 17:38:02 from (75.19.120.54):
In Reply to: Re: Clutch Hassle posted by Allan In NE on June 07, 2007 at 17:20:37:
Don't know what ya got going on here but ya got something not quite wright . It will work if ya have everything set . Done more then i can remember and never had one that it did not work on . Ususaly that lite will go out somewhere from six to nine turns in from the end of the clevis . This double shiften is not a good thing as it is working against the T/A . Are ya sure that ya covered everything here . Lets start again with setting the free travel , First ya take the pins out of the clutch bellcrank and the trans brake , then ya push the ft clutch rod back into the hyd assit cylinder as far as ya can next ya adjust the back rod out till ya feel resistance and feel the ft. rod move a wisker and i forgot to tell ya to pull the bellcrank back so ya can install the pin for the ft rod and set your free trave for the 9/16th at the clutch pedal and once that is all done move to the trans brake and with one hand push the trans brake lever back as far as ya can then push the clutch down to the stop and hold it there and adjust the clevis out till the pin will slide in after that is donme let the clutch up and then add the one to two turns to the clevis out then install the pin and cotter pin and lock the lock nut then on to the dump valve . and like i said to do there while holding the clutch pedal down after backing it out five or six turns start turning it in slowly till it JUST goes out then add the one turn and lock the lock nut while holding the head of the bolt.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
