Farmall Tractors Discussion Board
Re: Lost Spark On The M
Posted by Dan on May 11, 1999 at 19:38:47:
In Reply to: Lost Spark On The M posted by Rick Tobianski on May 11, 1999 at 19:04:41:
Rick, Make sure you are getting 12 volts to one side of your coil. The other side goes thru the points to ground. You shoul also see 12 volts on the opposite terminal of your coil( the wire going to your points) when the points are OPEN. You should read 0 volts when the points are closed.
Post a Followup
: Re: Re: Lost Spark On The M
