Re: Woods mower
Posted by the Unforgiven on June 13, 2007 at 13:51:19 from (66.146.249.116):
In Reply to: Woods mower posted by the Unforgiven on June 13, 2007 at 11:46:06:
Thanks everybody, I am starting to make some progress. I got ahold of the Woods people, they say it is a model 42CH, they like a tip speed of 16,500 ft. per minute, which translates into a 1500rpm spindle speed. Keep in mind here that I have one pile of A Farmall and another pile of Woods mower, no Cub. Reverse drive, crank speed pto???? Never been around a Cub. I was planning to drive it off the pto, do you guys think there is enough length under the tractor to cross the belt or should it drive off of the belt pulley shaft to get a better angle at reversing the rotation, crossing at the idlers?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
