Re: Woods mower
Posted by Nawlens_Gator on June 13, 2007 at 14:20:48 from (52.128.30.25):
In Reply to: Re: Woods mower posted by the Unforgiven on June 13, 2007 at 13:51:19:
Yea, the Woods guys have helped me a bunch. Guess I meant to say ft/min in my prev post (vs ft/sec).
For 1500 rpm at the spindle, the PTO pulley diameter will need to be 3 times whatever spindle pulley diameter you use.
Note they like to limit tip speed for liability reasons. For cutting, faster is better.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
