H has sloppy shifting
Posted by LinemanFarmer on June 17, 2007 at 17:44:07 from (70.253.111.220):
Well I finally got my wife her first tractor. It ended up being an H. When I bought it I knew the shifting was a little sloppy, but on the ride home it kinda changed a little. At first the the pin that held in the shift lever come out so I put in a bolt about the same size. Well the shifting is still sloppy and it just does not fell right going into 5th gear, in the others it feels a little better but you can still move the shifter side to side a little. Could I have a worn out fork of bent fork or is all my gears worn so bad and 5th is just terrible. It popped out of gear on my going up a pretty steep hill. The tractor really has not been abused that much by looking at it and running it. See what you guys think!
Thanks Derek
