Farmall Tractors Discussion Board
Re: Re: Super A backfire after shut down
Posted by RKS on May 21, 1999 at 21:13:19 from (152.205.116.245):
In Reply to: Re: Super A backfire after shut down posted by RKS on May 21, 1999 at 20:51:39:
The sources of ignition are of no concern with the engine running, since the exhaust has no un-burned fuel in it. When you shut down your hot super A engine, it continues to spin, and continues to carburate fuel and pass it into the stack where it explodes upon ignition. There could be a burr in the exhaust manifold inside the casting, or within the exhaust ports of the head, but somehow I suspect your muffler is causing the ignition. RKS
Post a Followup
: Re: Re: Re: Super A backfire after shut down
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
