Farmall Tractors Discussion Board
Re: Super A backfire after shut down
Posted by RKS on May 21, 1999 at 20:51:39 from (152.205.116.245):
In Reply to: Super A backfire after shut down posted by ddg on May 21, 1999 at 19:19:33:
it isn't the timing, since you switch it off as you shut down. Gas is spooling up and ventilating through the intake, pistons, exhaust ports, and into the stack and muffler. Somewhere in there, carbon deposits are causing ignition of the mixture. Try replacing the muffler (not much money) and you may feel comfortable and safe in engaging the clutch in high gear as you shut down, which will prevent the spinning and ventilation. Also, be sure and idle down as low as possible before shut-down. Cheers. RKS
Post a Followup
: Re: Re: Super A backfire after shut down
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
