Farmall Tractors Discussion Board
Re: Where to add oil
Posted by The Red on May 30, 1999 at 13:22:13 from (216.192.165.94):
In Reply to: Where to add oil posted by Levy on May 30, 1999 at 13:13:48:
Levy stand on the distributor side of the H. Look 5 inches to the right and you will see a 3 1/4 inch diameter cap with a wing on it, if original. It may be a flat plate with a bolt in the middle. Turn it counterclockwise and remove and add 6 quarts of oil. The oil actually pours through the timing gear cover into the oil pan.
Post a Followup
: Re: Re: Where to add oil
