Farmall Tractors Discussion Board
IHC Super C Hydraulic leakly pump(kiss of death??)
Posted by craig on June 08, 1999 at 15:28:00 from (163.185.8.61):
I have a IHC super C that has lots of form-a-gasket?? where the hydraulic pump connects to the engine block up front.
It leaks hydraulic oil and drips on the front tire area. With load like a posthole digger it will leak enough in a hour or two that I need to add more to make hydraulic work.
Anyone rebuild a hydro pump and ideas about it??
The front end of this tracor has some funny welding it all most looks the block area under the radatior was cracked?? I am afraid that under the layers of form-a-gasket?? I'll find the block area is the problem not the pump. Then I'll be looking for a front end....
Open to ideas... Thanks..
Post a Followup
: Re: IHC Super C Hydraulic leakly pump(kiss of death??)
