Farmall Tractors Discussion Board
Re: Farmall 300 shifting problem
Posted by Kent Morris on June 11, 1999 at 07:04:46 from (205.188.192.44):
In Reply to: Farmall 300 shifting problem posted by Hickory Hills Farms on June 11, 1999 at 05:48:18:
Hickory Hill,
Although you don't mention it I assume you have a Torque Amplifier (TA). If the shift lever is hard to shift out of gear with the TA engaged, then the clutch linkage needs to be adjusted. With the TA engaged, pressing the clutch pedal must release both the main clutch and the TA clutch. If the linkage is not properly adjusted, the clutch pedal may not fully release the TA clutch. These will hold tension on the transmission gears causing it to be hard to shift.
This may be a contributing factor to your problem. After years of wear and possibly sprung shifting forks, you may not get it completely out of one gear and get it into another at the same time.
If it is hard to shift try to adjust the clutch linkage and give it a try. If not follow Curt's Advice.
Good Luck,
Kent
Post a Followup
: Re: Re: Farmall 300 shifting problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
