Farmall Tractors Discussion Board
Re: farmal 300 clutch prob.
Posted by Ronnie on June 12, 1999 at 21:05:24 from (208.30.92.134):
In Reply to: farmal 300 clutch prob. posted by tlo on June 12, 1999 at 20:10:20:
You will need to split the tractor. If you can hold the two halves up when split, you can put in a new clutch. You will have hydralic lines, wiring, heat gauge, oil presure line, steering shaft and fuel line to break. I would think a good day would do it.
Post a Followup
: Re: Re: farmal 300 clutch prob.
