Farmall Tractors Discussion Board
Re: loosing fluid from right rear on IH350U 1957 and ..........
Posted by Ron on June 24, 1999 at 14:54:42 from (155.226.255.194):
In Reply to: loosing fluid from right rear on IH350U 1957 and .......... posted by George on June 23, 1999 at 06:41:07:
Concerning the "fluid leaking from the right rear tire". Do you mean grease or is it the liquid solution inside the tire used for weight? Where exactly is this "center bolt"? Is it used to hold the wheel on the axle? Nearly impossible to give an answer until we understand your problem in more detail.
Post a Followup
: Re: Re: loosing fluid from right rear on IH350U 1957 and ..........
