Re: Piston Sleeve Seals
Posted by Gary on February 08, 2002 at 16:21:54 from (152.163.206.197):
In Reply to: Piston Sleeve Seals posted by Farmall Freddy on February 08, 2002 at 12:24:59:
Fred, my experience has been,that unless you disturb the old sleeves,i.e. pop one up while driving out a stuck piston, there should be no problem. If you DO need to remove sleeves from the wet sleeved c-113 that As, Bs, Cs,etc. have, I use an oak 2X2 and a two lb. hammer and drive them out. That often works on wet sleeves.
Post A Followup
: Re: Re: Piston Sleeve Seals
