Farmall Tractors Discussion Board
Grandpa's old tractors
Posted by Ronny Bailey on July 30, 1999 at 00:46:50 from (209.30.66.215):
Hi. I can't tell you how happy I am that I found this place! I've just inherited two old Farmalls, neither of which has been running for many years.
The one I'd like more information on is the larger of the two. I would like to know how to identify it. It has 2 rear wheels with rubber tires. The steering wheel is mounted vertically and the steering shaft runs along the top of the tractor to the front. I think it only has one wheel in front for steering. On the back axle are long levers on each side of the driver. I think they stop the wheel when pulled back.
It is started using a good old crank. No electric starter on this one.
Any information you can provide will be greatly appreciated. I am in the Houston, TX area. Please e-mail me at ronnyb@flash.net Thank you!
Post a Followup
: Re: Grandpa's old tractors
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
