Farmall Tractors Discussion Board
Re: Grandpa's old tractors
Posted by Paul Fox on July 30, 1999 at 03:38:06 from (204.176.212.3):
In Reply to: Grandpa's old tractors posted by Ronny Bailey on July 30, 1999 at 00:46:50:
Single front wheels were an option on a lot of tractors. Rubber on the rear COULD mean a later model, or it could be that it was converted.
Couple of more questions:
Follow the shaft from the steering wheel to the front of the tractor. Can you see it all the way or is it covered by "body work"?
If you can see it, are the steering gears in the front exposed or enclosed?
Is the radiator exposed?
Do the rear wheels mount directly to the axles, or is there a casting that "drops" the rear wheels below the line of the rear axle.
Answers to these questions will narrow things down a lot.
Post a Followup
: Re: Re: Grandpa's old tractors
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
