Help -- Engine Bearing Clearance for Cub...
Posted by Kevin Hunter on February 24, 2002 at 15:25:40 from (207.50.161.204):
I have a 1956 Farmall Cub. I have a low oil pressure situation. I have replaced the gauge. It was not the problem. The tractor has about 20 lbs of oil pressure when the engine is started. As the engine warms, the pressure will get down to ZERO during hot weather. I have switched from 30 weight oil to 50 weight oil. The heavier oil helped, but did not correct the problem. I removed the bottom pan and used a micrometer to check the diameter of a rod bearing journal. I found the diameter to be 1.4965". The engine currently has STANDARD bearing inserts. I used Plastigage to check the clearance of the bearings. I found the clearance on the rod bearings to be 0.006". I found the clearance on the main bearings to be 0.007". My stumbling block is that I do not know what the original specifications are for the bearing clearance. I'm aware that 0.002" oversize inserts can be purchased for the rods and maybe for the mains. I'm not sure how much clearance I would have if I put in NEW STANDARD bearings or 0.002" oversize bearings. I'm looking for a reply from someone who is experienced in rebuilding cub engines to give advice as to whether or not oversize bearings will help or if it needs the shaft turned and the "whole ball of wax". BTW - I have looked at the oil pressure bypass valve spring. It is not broken, but it may be weak. I did not know of it's existence until I already had the engine apart. A new spring may have solved the problem. -- Any thoughts? Thank you. Kevin Hunter Willard, MO
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
