Re: H bull pinion shaft bearing
Posted by Bleedinred on March 20, 2002 at 20:02:55 from (67.227.207.158):
In Reply to: H bull pinion shaft bearing posted by Mike ISW on March 20, 2002 at 19:42:41:
Mike, You'll have to drop the bull gear down in the case to make room for the bearing cage to slide out. If you try to force it without doing so you will break the casting on the inside of the cage. You can pull the pto assembly out and work through the hole. Use a shim, large nut, etc. against the opposite bolt head to force the axle out as you unscrew the bolt that holds the bull gear to the axle. Ease the gear down and let her sit in the housing. Now the cage will slide out. I did a total overhaul last spring and had the top off, but this is much easier. Be SURE to account for those loose balls, and check the case for cracks--sometimes they get underneath the bull gears and break the case. Good luck and holler if you need to.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
