Re: getting discouraged / need help Farmalldan et al
Posted by farmalldan on March 26, 2002 at 07:55:02 from (64.154.26.248):
In Reply to: getting discouraged / need help Farmalldan et al posted by boog on March 25, 2002 at 18:50:13:
Boog,
If I follow your installation, I think you need to move the tee for the Lift-all to the excess flow port. All hydraulic oil from the pump should go through the priority valve. Without checking my manuals, I am wondering if you need a tee at all. However, this change should get the power steering working. If your Lift-all doesn't work, we will address that in time. Do you have a hydraulic cylinder connected to the power ports in the Lift-all. If not, you are forcing oil over the relief valve in the Lift-all when you pull the rod back. This will cause the engine to lug and hoses to vibrate, but no harm should be done for short durations. Does your friend's SMTA have the flow control valve? Does he have the pressure line from the pump tee'd into the priority valve? If so, I can't see how he is generating pressure for the power steering. Advise if this works.
Post A Followup
: Re: Re: getting discouraged / need help Farmalldan et al
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
