getting discouraged / need help Farmalldan et al
Posted by boog on March 25, 2002 at 18:50:13 from (66.73.129.55):
A couple of weeks ago I posted about adding a Behlen power steering unit to a SMTA. Received back several replies including Farmalldan's who stated I need a priority control valve. I ordered a greshen valve thru Force America and have spent the last couple of days trying to get it installed. After several trips to town getting hoses made I finally got it hooked up this p.m.. Problem is I still have no p.s. Previously the p.s. would work only if I pulled both the flow control( 2-way) and Lift-all levers back. Now when I pull out Lift-all rod the engine pulls down and 3/4" pressure hose from pump vibrates. p.s. starts to work then locks. Here is how I have it plumbed in: 1. pressure side of pump (3/4" hose) teed into P. port on priority valve (pv) and on to Lift- all 2. CF (constant flow) port on pv to 3/8" port on power steering unit. 3. 1/2" port on steering unit to tee in 1" return (bottom) hose from Lift-all. This hose then returns to fitting under flow control, then to hyd. filter and then to pump. 4. EF (excess flow) port on p.v. to flow contoll 5. T (tank) port on p.v. also tees into 1" return ahead of fitting under flow control. I looked at a friends SMTA and he had used the same valve. Everything was hooked the same except he had mounted the p.v. valve at the side of the Liftall as where as I mounted at the back of the engine under the gas tank. Also he did not have a hyd. filter. I figured while I had everything apart and had to have new hoses made it would be a good time to install one.
Do I have something plumbed wrong, or could it be the filter is causing the problem? As I said in my post heading " I'm beginning to get discouraged. It's not as if I have no mechanical knowledge. My son and I farm 2,100 acres and due what mechanical work we can, but this one has us both stumped. To top it off, one of the rear axle seals is leaking so I decided to fix that before coming in for supper. Had the wheel almost off the axle when I discovered that it was full of fluid. Sure glad I didn't get it clear off first. Don't know if the cherry picker would have handled it. In the a.m. will call the tire man and have them pumped out. Mom said there would be days like this. She just didn't tell me there would be so many. Appreciate all the advice I can get boog
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
