Re: Re: Re: Re: Re: 400-560 rear axle bearing updates
Posted by Jon on April 10, 2002 at 17:11:21 from (63.168.241.139):
In Reply to: Re: Re: Re: Re: 400-560 rear axle bearing updates posted by Old Dutch on April 10, 2002 at 16:04:56:
Yeah those bolts are rated at 300lbs or so for torque value, not worried about getting them over torqued. The only thing is, the more torque that is put on the bolt, the more of a preload the axle is going to put on the bearing because its pulling the axle inwards as the bolt gets tighter.
Post A Followup
: Re: Re: Re: Re: Re: Re: 400-560 rear axle bearing updates
