Re: Re: Re: Re: 400-560 rear axle bearing updates
Posted by Old Dutch on April 10, 2002 at 16:04:56 from (66.191.112.67):
In Reply to: Re: Re: Re: 400-560 rear axle bearing updates posted by Jon on April 10, 2002 at 14:53:29:
Snug them up real good. I used to have the wheel jacked up, put the socket on bolt and turn the wheel to torque it tight. That's pretty hefty bolt, dont think that you will get it to tight. Yes those washers can be a bit of a problem, but sounds like you have it.
Post A Followup
: Re: Re: Re: Re: Re: 400-560 rear axle bearing updates
