C200 Engine....how do you check the crank bearings
Posted by Don on April 11, 2002 at 14:12:44 from (64.105.216.218):
My I-544 is making a banging sound as the engin turns over. I pulled the oil pan off and nothing looks loose. How do you check for a bad bearing or rod/piston connection pin while all these parts are still in the engine?
Post A Followup
: Re: C200 Engine....how do you check the crank bearings
