Farmall Tractors Discussion Board
Re: 976????
Posted by Redfan on August 07, 1999 at 14:34:59 from (203.87.53.9):
In Reply to: 976???? posted by JEFF on August 07, 1999 at 09:10:48:
Jeff,
I can only presume from your Email address that you are posting from the States and if so, I wonder what Online Site you were visiting when you noticed the 976.
The 976 I know of was built totally in Australia using the same engine as the 866 but fitted with a Turbo. Made it pull like one thing but they had some driveline trouble, so with the release of our 86 Series the 986 recieved the same driveline as the 1086. Problem solved.
As far as I know they weren't ever exported but I'll stand corrected if you know otherwise.
Engine was Australian built of Neusse design. 358 Cubes, rated at 2500rpm. Same Geartrain style as the American 66Series but locally built.
Hope this helps. Redfan.
Post a Followup
: Re: Re: 976????
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
