Re: Generator or Alternator
Posted by Hugh MacKay on April 20, 2002 at 23:00:12 from (209.226.247.10):
In Reply to: Generator or Alternator posted by Jim on April 20, 2002 at 19:34:32:
The purests in tractor restoration will tell you generator is a must. I personally don't agree, I would go with alternator. I did two of them ten years ago. use same alternator as GM was using through eighties. Scrapyard prices are around 15-20. You need a double pully, for positioning on A or Super A. Just weld a flat plate on current mounting bracket and weld pieces to that for mounting. Ask Bob M for his wireing diagrams.
Post A Followup
: Re: Re: Generator or Alternator
