Re: Re: Generator or Alternator
Posted by Dan Kelley on April 21, 2002 at 06:19:46 from (216.229.35.110):
In Reply to: Re: Generator or Alternator posted by Hugh MacKay on April 20, 2002 at 23:00:12:
I won't state either way: generator or alternator. That's up to you; authentic or not.
However, GM has a great part available. When you rebuild a GM alternator for a tractor (a very easy process), try to find a marine voltage regulator. The voltage regulator on a common GM alternator is inside the unit. The marine regulator (also called self-exciting) is a one wire hookup. With this special regulator, the charge wire is the only thing you need to worry about. Pick up any hot-rodder's magazine, and you'll see one-wire alternators. This is simply the GM alternator with this special regulator in it.
Post A Followup
: Re: Re: Re: Generator or Alternator
